Timber forwarding and winching costs
Hi.  Was just wondering what the current rates are per tonne forwarding.
Plus rates for winching 2 man and tractor set up.
This is all for first thinning.  Not clear fell.
I'm running a alpine tractor and 6 tonne trailer and I can't see how the money adds up.
All advice given would be greatly appreciated.
I assume prices would be plus vat unless stated.
Edited by Root and branch sw
Forgot to add vat
We were paying £32 a ton to have oak winched and stacked a couple of hundred meters away. That's on steep banks.
We're just starting to do a bit ourselves and it's looking around £35. Most people where we are are similar.
That's thinning not clearfell and plus vat.
Edited by gdh
I haven't got much experience with softwood to be honest, did our first bit the other week. It was only about 50 tons on nice ground but it worked out about £20 a ton so I can't see it paying on our small scale (tree shear/excavator, forwarding trailer and winch when needed).
One way to get a rough extraction cost is just take off transport and standing cost from the final price.
Eg oak is about £60 a ton delivered in, minus £10 transport, minus £15 for standing timber makes £35 about right.
Edit: The problem with softwood costs is your competing with harvesters that will do 100ton an hour so even if you find a small site with cheap wood it's difficult to justify it.
Edited by gdh
I hope that isn't felling as well or really isn't worth it as no way can a 2 man team fell, sned, winch, crosscut then forward a wagon load a day with compact machines at that rate I'd need to be hitting 2 wagon load a day to start making it worth while.
What gdh says sounds more realistic.
This is where it all gets difficult.
I got called into extraction of felled timber as a sub contractor. Environment agency had felled the all over the shop. So I winched it all into piles now accessible to the tractor.  Now got to load and haul and stack on landing. So I'm just a middle man really call in to tidy someone else's mess.
