Saw not run for 15 year s
Jack the dog
Here go s first post . Just bin given a jonersred s 50 e  to have a play with to see if I can get it going  I don't think it has bin run for 15 year s dose not seem to be in bad nic re place d fuel line s carb is well clean  bone dry was well . Plug s good  has descent compression .any tip s on starting it .must be  early 70 s .thank steve
Edited by Jack the dog
No obvious reason it shouldn't start but it may not keep going as rubbers are likely to be perished.
I was given a big saw with 13-year old mix in it that hadn't been started in that time:  I tipped out the filth, poured in some fresh, swilled it round, tipped it out, put in fresh and it took just 12 pulls for the machine to be purring.
