Brand new Stihl 461
Hams25
obviously but its probably going to hammered hard through beech and oak so if I need to baby it for a bit I’d like to know
Best not to I think. If your not firm with them at first they'll never learn.
Seriously though I think you can create a glaze or something on cylinder if you pussy foot about when new.
Run it flat out and hard but for short periods (heat is a killer) and DO NOT sit it on idle for long periods.
The saws bore, rings and piston have rough surfaces and you have a short window where they can bed together to create a decent fit and this is best done early in its life and is done by running it flat out but avoid long big cuts where excessive heat will build up.
