Sign in to follow this
smithers1603
Husqvarna 3120xp problems
Hi
Does anybody know if there is a special tool for tightening the exhaust bolts on the husqvarna 3120xp. Both of ours have both gone down with the same problem in the last couple of weeks. First one was put on the bench by a member of staff saying the baffles had gone, after taking a look both exhaust bolts where missing, also after checking the threads in the head they where gone so I've had to helicoil them. New bolts have come but I can't get anything inside the exhaust holes to tighten them.
Any help would me much appreciated
Regards Steve
Share this post
Link to post
If I am reading parts list correctly, no threads in cylinder the nuts are on the front of the exhaustHusqvarna 3120 XP (2003-11) Chainsaw  schematics Page J
Share this post
Link to post
The real early ones had threaded holes either side of the exhaust port rather than the square retaining bolts. Not sure what the OP means about the rest though??
Share this post
Link to post
Early 3120 had long bolts with squared ends that slipped into cut a ways in the cylinder, the later cylinder has 6mm threaded holes and was from the k1260, the screws should be allen screws to enable tightening them.
Share this post
Link to post
Thanks for the replies, I was scratching my head looking at the square heads on the bolts, I can see the difference now. I will re order the correct ones now
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
