 Sure if anyone is familiar with these engines. Its a single cylinder air cooled diesel. Just lately, the engine will run all day,, but loses all its sump oil. There is no external leak, engine rums fine, starts ok etc. Just wondered if this fault is a simple fix, or is it a new engine job. I presume the oil is getting up into the cylinder head and burning off, in which case piston rings?
Can't offer much advice, but I (with help from a friend) had to strip and rebuild my oc95. Got the cylinder relined and new piston etc. If you google, you can find the Kubota workshop manual for free download.
