Just been on the Axminster site and it looks like they're clearing the creusen line. The slow running version is no longer available and the standard one has been reduced to £90 in 240v or £110 is think in 110v. Big saving if they're any use to anybody. They've got standard 20mm wheels on
Sent from my iPhone using Tapatalk
Could you tell me the benefit of a slow running Grinder? Less Heat build up maybe?
Yes better if you have any older tools that aren't hss. Also if I remember right the slow running one came with a 40 or 50mm white wheel as standard
The slow running one comes with 2 x 50mm white wheels 80 & 100 grit I think and is all I use for all my turning chisels, straight from grinder to the lathe, brilliant bit of kit.
I second that👍
