Which course would you recommend? I don't need a lecture on PPE (I have bought it all!) I don't need to know how to start a saw or basic maintenance.
I am just interested in learning how to cut limb's which are wider than bar length on the ground, or in the saw horse for that matter.
I appreciate it is easy for an instructor to spend half a day talking about the importance of PPE and kite marks etc, but I don't need to pay for that!
Go on a training course but I am sorry you will have to talk about PPE basic maintained and starting a saw as the course won't just be for you unless you want to pay a small fortune for it on a ones to one basis.I would put money on it that you will learn more than you think you know so to keep yourself as safe as you can do the course, training is cheap really, a made of mine thought he knew it all about saws but top and bottom of it he knew f--k all nearly took his arm off with a saw 18 month off work and I advised me more than once to do a couple of courses the training would of been cheap to 18mths off work.
Stop!
Get some training!
If you don't know about bar length cutting, you know f**k all about chainsaws and have clearly no experience.
Do not expect professional als to condone dangerous behaviour with a chainsaw.
Ok that may have come across as slightly harsh, but it's better than losing body parts.
[emoji3]
TOTALLY agree with the get some training and I could give him some advice but it wont be what he wants to here,
I bet Husqvarna or stihl have a series on youtube with explanation of the crosscutting,the dangerous parts of using the nose of the bar, standing uphill of log when making final cut etc. For simple crosscutting, you can cut twice the length of the amount of bar sticking out clear of the saw. Beyond twice the length, you have to cut a hole to allow your saw in further to the middle uncut bit, or if it's only firewood, cut all round then split some chunks off with your ax or wedges. Just don't dick around with the upper corner of bar nose in any kind of flaky, upward cutting careless way. Also, don't cut around metal barrels or wire etc, metal contact gives the worst kick back and catches a lot of home owners out. Don't get your neck in the way of the saw, or your main arteries.
Iisten to your saw
Burying tip is acceptable
Watch out for tensions in limb as you cut
Roll ,Twist etc.
If at height
Perform a square cut
Under first
Then sides
Then straight down through prepared square
Which drops large limb almost straight down , a little drooping towards stem though if fast enough no problems .
You can just cut through middle of limb then cut half way through
Use your instincts
Try not to overheat bar
Keep teeth sharp
Sent from my Y635-L01 using Arbtalk mobile app
