Hiab leg sprung a leak
Al Cormack
The metal pipes are replaceable relatively cheaply, a good hydraulic supplier will have straight lengths of the pipe and fittings with olives, if you can get access to a pipe bender your sorted.
I`ve replaced quite a few on my crane from the leg control valve to the legs, the pipe was either 10 or 12mm od, got the same size from the hydraulic supplier, took the old ones off, and copied them with the new pipe using an adjustable hand held pipe bender.
Sounds pretty straight forward. I'll have to find the other end of the pipe...[emoji106]
Thanks Craig.
http://www.cormacktreecare.co.uk
