Right
Looking for something like this - any ideas? What is it called? Where can I buy one? (Haven't got time or equipment to build one).
Ideally it would dismantle/flat pack - aluminium tubing etc.
Cheers
ps if you have used a small chipper you will know why one is needed!
Right
This one looks quite simple and should be easy to knock up.
[ame]
[/ame]
Still don't know what it's called or where to buy one though.
that's an accident waiting to happen !!!
[ame=
[/ame]
much safer to use one of these ! stack all you small stuff on it first then put a larger one on top so it doesn't bounce the saw about once you start cutting or you can put a couple of bungee straps to hold it tight together !
