Husqvarna 540xp problem
Arblife
  • Replies 32
Cut cookies or rings flat out with out letting off the throttle in between cuts and it should retune and settle down.
Thanks MattyF, I will give this a try tomorrow. Its so annoying when the saw does this. Plenty of big logs at the yard
The plugging in does ( unless you have the software ) but re setting the A/T your self can be donre as above buy cutting the full length of the bar for 3-5 mins as per the book .
OK thanks....... I wonder if I can find the software online :confused1: ... and I am going to try the reset tomorrow..... ive also heard that once started every day run full throttle for about 30 seconds and that kind of sets it up ???
