Saw will die with full throttle.
Hunter
Having problem with my saw MAC 838 38 cc saw.
The saw will start easily, and rev nicely while throttle leaver is half way out but it wouldn't idle , it will rev up and respond nicely without hesitation to my finger on the throttle but will die suddenly with full throttle.
I had the saw from new and never changed factory carb setting.
I have checked and changed fuel line, fuel filter, air filter, cleaned the carb which was already clean and rebuild the carb with service kit also changed spark plug.
I have also tried to run the saw with fuel cap off in case vent hole is blocked.
I have Pulled the muffler and piston looked fine, checked compression and it is 155.
Any suggestion.
  • Replies 26
Mine used to start fine but die on full throttle. I tested the coil by removing the recoil starter and spinning the motor with an electric drill - making sure the plug is earthed by touching it to the engine. No spark at all.
