Anyone know where I can get one of these spill trays for chainsaws? Thanks in advance.
It's a plant nappy, most places that sell spill kits have them. They are expensive and I would use a liner of a few oil spill squares inside it. On all but the most rigorously audited sites I'd use a drip tray with oil spill squares as a cheaper option.
I keep my fuel can in a rubber tub to stop it spilling in the back of the truck and any small leakages on a customers property, it a rubber tub like you would see a builder or plasterers use , only about £4-5 depending where you get them from
You can use saw dust, cat litter, and sand . Look on line for spill kits and then see if you can set a kit up cheaper !
I bought a large tray from B&Q and use either items . Then once oil or chemical is soaked up bag it and tag it for disposal.
You can get plant nappys on eBay. We use them, they work well, look the part for commercial clients and last for years.
Sent from my D6603 using Tapatalk
Get some growbag trays from B&Q and some spill mats from RS or a garage supplier. You can buy it on the roll for about £50 should last ages.
