That is not a original serial plate
Ditto ifor plates are not stamped. It a job to explain but each letter looks like all dots to make each letter, well that's what mine looks like.
Should be a sck number with about 6 zeros at the start
Should also be stamped on a frame above serial plate
Also laser cut on side month and year is stamped on wheels
Phone ifor williams customer care to check which is free
Pretty sure you can ring ifor Williams up and give them the numbers and they tell you its got history on file they then charge a fiver plus vat to tell you the details. If there is no history on file from new they will give you this information for free.
When I changed the back lights on my IW to led`s I noticed they had hand written the serial number in felt pen behind the units. I dont know if they still do this but its another concealed number thats worth checking if you are having doubts.
Bob
