3 minutes ago, Stihlaround said:
Could it be possible that a major clutch could still be in it, the man I bought it from reckons its a single clutch but he's not sure
Does the PTO still drive with your foot on the clutch? The County is IPTO  and I hadn't considered that.
There's no clutch at all, only grinding, its been parked awhile, don't think its live drive
I see I had replied much earlier in this thread and forgotten about it.
Anyway my experience of tractors parked up to a long while is that the clutch sticks to the flywheel and won't release so if there's grinding I'd suspect the gearbox.
Story is that he had a drum mower on and he was mowing hay, it started making a knocking sound from the clutch area and then the clutch went, it wasn't started in 2 years but fired up instantly when a battery was connected the other day
If you're lucky the centre will have ripped out of the driven plate.
46 minutes ago, Ratman said:
Sounds like release bearing shat itself.
Are those hard to repair?
42 minutes ago, Stubby said:
We used to have a 1976 Ford Cargo horse box with a six cylinder 6 liter engine. Would this be the same one ?
Not sure
Thanks for your input fellas, appreciate the help
No just put a new driven plate in
you should be able to take the top cover off the gearbox and see if the first motion shaft is turning
