My Husky 343R brush cutter has developed a fault. I fitted the bramble basher blade and as soon as I rev the machine the head assembly is rotating under torque.
I have torqued up the clamping screws but no fix. Is there meant to be a keyway or spline that prevents this or have I snapped something.
Cheers in advance.
Craig
Cheers in advance.
Craig
Yes . There is a splinded adapter . Leastways there is for my 545RX .
Cheers in advance.
Craig
Do you mean the gearbox rotates on the shaft? I have had to fix this on several brush cutters and if the clamping bit is cracked I use an exhaust clamp over the lot.
Yep the gearbox is rotating on the shaft. I can't believe it relies on two bolts to stop it rotating, surely it should be splined? Poor design, thanks openspace, I'll look at that option.
Thx Craig
Sent from my iPad using Arbtalk
Thx Craig
One on a Stihl and one on husky, yes I know the guarding is inadequate
