Do you mind me asking what your thinking of doing with MultiOne & Avant attachments ?
I want to use an Avant bucket on a multione. Nothing hydraulic, which woukd appear to be different.
We had been selling Avant loaders for fifteen years, In April 2017 we switched to MultiOne still having Avant products & attachments in stock, you are correct thinking the hydraulic connectors are not the same, We have not had a problem fitting Avant attachments to Multione & not had a problem going the other way, Multione attachments onto Avant.
Hope this helps you & good luck.  Beddoes Ltd.
Thanks. It is the XL light weight bucket. At 1800mm the MO is 660 litres, Avant is 900 litres. I shift woodchip around so the extra capacity will speed things up. The Avant bucket is heavier but it's just woodchip so I don't feel the 100kg is going to be an issue.
No problem, Pleased we could help.
5 hours ago, warren said:
Thats good to know ... the mo has a lawn aerator but avant doesnt.
Saw one working a couple of months ago & yes it work'ed ok , taking into consideration it was mid summer, it was been used on some very damp land.
