We find that a lot depends on the timber species. Sometimes a push, sometimes not. With chestnut, willow, softwood etc you get a lot of boring as the soft timber absorbs the force of the cone. Ash and beech are much easier to split. On something like a big crown junction on a chestnut we sometimes put a couple of cuts in the length of the bar to start her off, that always seems to work. You can always flip her over and bore down into it like it's a stump.
Yes I have experienced the differing species . As you say some times you need to give it a shove to get the helix to bite in soft wood but once in it need to pull itself in to avoid the boring effect .
It may be that I just need to have a bit more power as the hydraulic motor is worn, or it may be that the cone is not a good design.
It may be better if you start near the end instead of going straight for the middle ;)
Kev7937 mentioned this earlier.
I was in too much of a hurry in the first video and will give it another go on a decent bit if ash starting at the end and video the result if it improves things
