  • Replies 43
U could try to pollard it but i doubt it would survive, be too harsh and taking to much off in 1 go.
A local estate has tried to pollard some big oaks (althou not quite as big as that 1) in a SSSI and a high % die, just too much stress.
A lot of the ancient oaks badly need re-pollarding but probably been far tong since they were done and wouldn't survive it, probably a few hundred years since last pollarded
Possibly if its in decent health apart from crack in good soi and has a wet summer it might live.
If u try and fail u can still fell it anyway, if u fell it it doesn't have a chance
Possibly u could limb the leaning limbs off it leaving the straight up leg, so taking the side pressure off but leaving middle 1. If the side legs start to grow at the pollard u could mibee take the middle 1 out a few years down the line if needed
Edited by drinksloe
Hard to say for sure without seeing the tree in person. However, if the tree owner wishes to retain it, I reckon it should be possible. Some good advice from drinksloe above. Can the track below it be diverted a little, what is there it could hit if it fell? A few neters reduction of height and width can reduce stresses low down by a surprisingly significant amount, so all hope is far from gone!
It's impossible to say without actually looking at it. However, it might be possible to regain a reasonable level of stability by crown reduction.
Pollarding it is likely to result in so much dysfunction that it will die within a few years.
Assessing the risk it poses (i.e by considering the target/s, size of the part and the likelihood of it failing) should form the basis of your management decision in this case.
  Duncansimpson said:
Yes definitely a pollard. Cut it off about 3 ft above where it came off and good for another 200 years. Think of the wildlife.
Its worth a go at least, and if it dies, call it vertical firewood seasoning or a habitat pole.
Read more
