Clarks do small spline 3/8 rims. But only 7 tooth. If you want 8 then you need the clutch drum with the standard spline.
550 handles 3/8 pretty well on 15". Will be fine in Oak.
  • Replies 36
  woodwizzard said:
Have run 3/8 on mine for the last 4 odd years, normally on an 18" bar. Runs it fine and anyone that has used it says what a ripper it is. Chain speed is increased as the sprocket size is larger.
3x8"x7 will of course produce a higher chain speed out of wood than .325x7 - but .325x8 would about even that out.
Both the larger sprockets will give the resistance from actual cutting more "arm" to work with though, against the torque of the saw - meaning that the rpm and chain speed will drop faster in wood.
There really is only one way to find out what works best in a given situation, and that's the obvious one.
  CutterSy said:
As long as you find a small spline sprocket. It's just sprocket, bar and chain.
A small 7-spline 3/8"x7 is Oregon #18720, Husky #504 52 30-02.
  Ferguson system said:
One of my customers prefer 3/8" (15") over .325 on his Husky 550 xpg.
There is nothing wrong with testing the options, and don't forget the .325x8 option.:001_smile:
Sorry to derail the thread some what but why would you want to run a 3/8th chain on a 550. Surely it would cut slower as it is creating a wider kerf.
Have been running the narrow kerf oregon chain but finding it a bit delicate- snapped a couple of cutters but does seem to cut fast in the timber.
Sent from my SM-G900F using Arbtalk mobile app
Read more
