If you are stopped for being over weight/GTW you MUST be weighed. They can not use the plated weights.
However this is about licences.
If you are stopped for no trailer towing licence then they do use plated weights.
This is clearly not just about license, weight is obviously also an important factor.
I do not claim to be 100% correct, but I'm sure I'm wrong.
  • Replies 182
The letter refers to the weight VOSA will apply, IE actual weight, not plated weight.
That is for C&U not licencing.
Licencing is done on plated weights.
Can you on your car Cat B licence that allows you to drive up to 3500kg drive an empty 7000kg lorry that has a real weight of 3400kg?
No you cant as its the plated or potential weights that are used.
So tell me all this trailer stuff is interesting (once again) As I passed my test in 1968 do I still need the man with the red flag to walk in front of me? According to SWMBO I do.
Sent from my SM-J320FN using Arbtalk mobile app
No!
You need to hang up the keys, step away from the vehicle and go catch a bus :001_tt2:
Yes it does, for determining whether you are overloaded, not for determining if the driver has the correct licence. :thumbup1:
What are you smoking / drinking?
This thread was about IF you need a towing LICENCE or not.
Not if you are over weight.
SWMBO is always right.........
You clearly have a poor memory or is you thats "smoking/drinking?"
