  • Replies 24
Oak you really need to split, to expose the heart wood. Have you got a processor? If so then log it all onto pallets with heras panels front and back as high as the panels. Wouldn't bother with the tarp. on the top for a few months, get as much wind and sun as possible. Job done.:thumbup1:
nothing wrong there mate..
you walk before you can run..
Cheers, did abit last year but no where near as much as im planning to split this year, i know what im letting myself in for though... :001_smile:
No prossesor, i have an axe and my trusty ms341 :)
OK, then if you're planning to do logs seriously you will need a log splitter at least - cheapest way is to make yer own. Then you can billet everything to speed up seasoning. I billet all my Oak and stack on pallets.
I started doing firewood with saw and axe, sooner or later you'll save up for a bit of mechanisation!
All the best with your enterprise.:thumbup:
Yes thats the plan, ideally i would like a small yard tractor with loader and splitter in years to come, although il stick with the axe for the mean time :)
Yep stacking on pallets is good. I would make a wall of split logs around the outside then just throw the rest in to the middle. When you get to the top make it dome shaped so when you throwover a small tarp(just to cover the top) the water will run off.This will only let the wall logs get wet which will dry out in no time.
