Hi guys as the title suggests I have bent the jockey wheel on my trailer and I'm not sure how to get it off as it appears to go through a bracket which is welded on, the only way I can think is to jack up the trailer and keep winding to see if it seperates. Just wondered if anybody on here had an idea before I try.
Cheers Chris
Yep it will wind off the thread . Alternatively remove the axle and slide the wheel out . This is assuming what you say in the title is correct and its the wheel that is buckled and not the threaded shaft . If its the shaft then angle grinder / disk cutter .
Edited by Stubby
Cool as I thought then jack it up. It has bent above the wheel on the bottom shaft so still unwinds but stops winding up when it hits the kink so should be simple to change. Cheers guys for quick response.
Chris
