  • Replies 188
Thankyou, i need to ad a few more tools to my arsenal first as it's quite hard to turn but its on my list :001_smile:
i know what you mean did this one yesterday did not go as deep as i had planned and not as smooth as i would of liked but still a good learning curve
all christmas presents
i am off to ASK Tools woodturning and woodworking tools and machinery
tomorrow to get my christmas presents
so will look at that sovereign stuff need a selection of rests
tried to make some but not as pukka as i would of liked and always a few more chisels never go amiss
also need some more glue any advice:thumbup:
Looked on there site the chestnut superglue is good just make sure the surfaces are flat, a good hot glue gun works well too as you can re heat it to remove it easier. I rarely use glue as i have a chuck and a thread screw and then i turn a spigot the other end to fit into the chuck.
think you can see on left i generally glue a 3 inch ish peg on so no wood is wasted and find spigot slips more or distorts when i crank it up
or am i doing something wrong:blushing:
basic pva usually but it,s a bit cold at mo
put peg in jaws then put block on and hold tight with spinner bit from other end sorry dont know technical stuff
The way your glueing it is fine, with the spigot i do a dovetail so it grips the chuck better. when you do spigot turning don't turn the out side of the bowl to finished size as when you turn it over to place spigot in chuck there might be a slight wobble so then you can do final cut (does this make sense??)
If distorts when speed is turned up i would guess that it's slipped on chuck slightly.
Edited by Ian Leach
I don't no of any forums i go to a demonstration once a month which has wood sales tools, glues, polishes all kinds of stuff. As i'm still a novice turner i always use a spigot like that as i find the other way on slip in chuck and the whole piece can be knackard.
  • 1 month later...
Well not done anything for a while for various reasons but here's one i done today, it's a salad bowl made out of walnut with a beeswax and caranuba finish. Also a pair of salad hands which still need sanding and waxing also made from walnut.
