by "low profile" do you mean narrower width ways ie smaller kerf?
thanks carl
That and cutters not so tall ...hence lopro
  • Replies 42
Yes, but they "happen to" cut a narrow kerf (narrower than regular 3/8") as well.
As the "chassis" of those chains are lower and differently shaped as well as the cutters, they don't really fit on regular 3/8" drive sprockets, and the nose sprocket of regular 3/8" bars are incompatible with them (usually doesn't work at all).
This is a challenge on the 550xp etc - but it can be done with using a standard 7-pline drum from/for the 562xp and the standard spline picco/lo-pro rims from GB (Stihl ones only come with the Stihl only "mini" 7-spline, and are no-go on those saws, or anything else but Stihl).
Regular 3/8" drive sprockets are too small, and about like running the chain on a sprocket that has been worn well past its useful "life" - but sort of works if you can live with the chatter and accellerated wear.
Then there is the question of why anyone will want to do it at all.....:sneaky2:
Edited by SawTroll
Well havent been using it that much. Its first outing was loggin up down the yard was cutting really well until i mutilated the cutters on a stone in some timber. Sharpened it back up by hand no problem but took the rakers down a touch as i had to go back a bit on the cutters but it is a little aggressive at the moment.
It's that typical new chain just been fitted syndrome!.... they seem attracted to stone and metal. :sneaky2:
Did you notice much difference in cutting speed?
cheers, steve
  • 3 weeks later...
Well it the chain is good but unfortunately the nose sprocket has broken up on the sugi bar! Didn't even last a month!! Perhaps I should have stuck with oregon!!!
Sent from my SM-G900F using Arbtalk mobile app
Really! Wasn't expecting that to happen!! Was it oiling okay?
cheers, steve
