Thanks that great. That's exactly what's happening. When I bring the visor down it doesn't go all the way, when I push it down full it moves the muff. Kind of annoying. Cheers
Sent from my SM-A300FU using Arbtalk mobile app
I'm glad you mentioned it as I'd initially bought the Peltors but never fitted them. I bought the basic helmet and then bought the mesh visor and MSA carrier separately which then meant I needed MSA ear defenders. I would have assumed that the Peltor system would have fitted no problem even with the vizir fitted.
It might be possible to trim the vizir but IMO you'd be better switching to the MSA set-up which works well IMO with the vizir even with the mesh visor also fitted which is what I use.
I bet that's well handy when you're working on the ground looking up and the climbers saw dust is going in your eyes! Can you have the mesh one on too?
Not sure if you were asking me but yes you can have the mesh visor on too, that's the way mine is set up but had to take the visor off to get the Peltor ear defender on.
I use the MSA system on my ground helmet but with a different visor.
Edited by R Mac
....just bend the wire , so it misses the visor....
It's worth a try although it would need bent quite a bit as in the 3rd pic down the wire is under the vizir and already the ear defender is pushed back to touch the rear of the cutaway section on the helmet.
Excellent! Thanks for taking the time to post that [emoji106]
Just noticed that the pics I'd posted to illustrate things aren't visible, I must have put them in another album so I'll post them again for clarity. Sorry bout that.
