  mickdundee said:
They're brilliant Lazarus. How does the jam chuck work. Do you need the tailstock in for that
Sent from my iPhone using Tapatalk
No its just a gentle taper cut onto about 6" thick MDF so you can "jam" various diameters into it, the MDF seems to grip enough to finish I do put the tail stock up initially then remove for the final finishing of the center, If I remember I will take a couple of snaps tonight and post them for you. Also it helps get all the fruit similar sizes which always helps as they need to be similar to fit the chuck.
  • 1 month later...
First attempt at a pear today. Just ran out of time to get the stalk done before my kids swimming lessons! I think it's a bit on the big side but pretty happy with the shape. And I've got a jam chuck now that takes the apple and pear. Hopefully finish it off on Sunday 43fc167b8889e3f3d6524a13dc128601.jpg
I'm trying to get a half decent bowl worth of fruits turned at my aunts request. These two are firsts but I've got some different timbers to add a bit variety.
Buy a cheap bunch of plastic grapes, remove the fruits and replace onto the stem with turned grapes in purple heart, they look cool, and fairly simple if a little repetitive.
Read more
