130yr old Indian Bean.
Andy R
Looked after this tree for the last 6yrs. When we first went to this customer it was very poorly and they were worried they would lose it. In the time that has since passed it's been fed, aerated, load reduction and deadwooded three times. Today we were to reduce some of the weight on some scarred limbs towards the surrounding properties, 3 or 4 deads to remove and support the lower limb taking the strain off the old cables that have been there for a long long time. The supports have now created just enough slack in the cable, and holding most, if not all of the pressure. We don't want to remove the 3 or 4 cables in the tree as they have been there for sometime, and apart from the lower one are doing a good job.
A nearby arboretum have asked for permission to come and view the tree..:thumbup1:
Thought you may like to see the result of our efforts, all comments or advice welcomed.
thanks..the span of the tree is very important, we haven't taken any weight out of the lower limb at all and the original size and shape of crown has been kept...what you see now is how nature intended it, obviously we have taken some weight out of certain limbs but keeping the overall size and shape was rule 1.
Someone years ago fitted the cable but it has outgrown that method now, the supports are perfect for the job.
yes they did mate...twice, which was nice. :)
Apologies for skimping on the support description earlier, was on my way out. There is a 10mm threaded metal rod through the post, screwed 1/3rd way into each point on limb and then a foot into ground. To look at it, it just looks like someone has propped a post on a slab, but hidden from view it is fixed top and bottom. I'm happy with how it worked out, looks minimalist and old fashioned, with a high tech (lol) inner secret. :D
