Guide bar
deri
I have a Parker chainsaw 20" bar.
When I put the alaskan mill on it clamps the bar too tightly and the blade does not run very well. Can I get a better quality bar to fit the saw.
I also have an old partner 550 which could do with a new bar.
Sent from my E5823 using Tapatalk
If a " Parker " is a Chinese saw , as I suspect it is , the bar is probably softish . Maybe a better quality bar would be the answer . Its determining the type of mount . Best take the bar in to your dealer and see if there is an Oregon equivalent .
I use a similar saw on the 24" mill with an Oregon bar, the clamps must be correctly sited especially at the nose where the sprocket sits, I also noted the clamps do not have to be super tight to grip the bar safely.
It's a Chinese eBay special😀
Good enough for my needs at present time until I invest in better.
The bar is soft in comparison to the other saw I have.
Thanks for the input👍
Have a look at the Chilling or Chinese milling thread:thumbup:
