I've just bought a rayco rg20, good condition but got it home and compared to my smaller grinder and it's too wide?? All the specs I can find in the machine says its 29 inches but this one is 34 now I've measured it. Did they ever come like that? And how can I get it back to 29 inches so can get through smaller gates?!ImageUploadedByArbtalk1472286334.371686.jpg.6eb200f9906aceefb99127b46e6c5de2.jpg
Could work I'll have to take the wheels off and measure across to see if can get to gate size. Bit annoying as everything ive read on this model says its 29 inch
Β
Β
They don't look like they are. I've measured the inside of the wheel to the outside at 3 inches so the plywood wheel idea would get it down to 29 if can get some made that'll hold the weight. Can keep my smaller machine for gateways but was planning to just have the one machine
  • 5 weeks later...
Mine has been reduced in width to 28".
It came with some rubbish 8" standard trailer wheels on, but the axles had been shortened and the hubs set further in. They were just too small and no traction. The original wheels would no longer fit. I looked at hub spacers, but I bought it for narrow access and so set about looking for a decent solution. Turf tyres was an option, but they tend to be too wide. I eventually sourced some 10" mini tractor style wheels which are big enough and give good traction. They have a very close clearance, but I now have a very capable machine which will get through a very small gap if I can't get a bigger machine in.:thumbup:
SG
  • Β
Arbtalk.co.uk is a hub for the arboriculture industry in the UK. Β
If you're just starting out and you need business, equipment, tech or training support you're in the right place. Β If you've done it, made it, got a van load of oily t-shirts and have decided to give something back by sharing your knowledge or wisdom,Β Β then you're welcome too.
Γ—
Γ—
