Denso 8971128652 is the OE part fitted by Isuzu - I've only got a reconditioned original on the shelf here (hence knowing the part number!) so can't find you the aftermarket make/model. A decent auto electrician will be able to match this part number though.
could the reverse solenoid be rigged up in parallel with the starer so that it helps with this problem?
The forward/reverse spool is mechanical on these - you could theoretically wire up the no stress to allow the rollers to turn in whichever direction they are set to with the control bar but this could equally make the problem worse if the numpty that turned it off whilst set to feed subsequently cranks it back over whilst still set to feed...
