I'm with Felix
I've just been out and measured the handy shaft.
The outer shaft is a slack 1 inch with a locating button that pushes in 32 mm from the end
The inner shaft is square and about 4 mm across flats. About 10mm inside the end of the outer steel tube. My vernier is at work but I think it should reach in to give an accurate measurement tomorrow.
  • Replies 21
I'm with Felix
Shaft is 5mm square. However I believe the Stihl shafts protrude past the tube so there might be less engagement to drive using the Handy / Ryobi unless the tube goes in further.
I use an Expandit for small hedges and topping a Florabest long reach, part of an electric split shaft system for the big stuff. All will fit the Stihl engines and the carbon fibre extension shaft. I trim a bit off the article outer casing on the Expandit to make it locate in the Stihl connecting sleeve. On the Florabest I just remove the Stihl connecting sleeve and use the Florabest one complete If I could work out how to post pictures on my new phone it would help, phone and PC currently refusing to talk to each other. .
Sent from my SM-J320FN using Arbtalk mobile app
ok great, once again, thanks to arbtalk!
so i can now get a real cheap Expandit attachment, 10 mins on work bench and i've saved myself £150!
Let us know how long it lasts! :D
