Hello,
2005 L200 k74. The alternator pulley has developed a squeek/squeel. I sprayed wd40 onto the central bolt/bearing area and it went away for a few days. Anyone know where I can get just the pulley from?
Rather avoiding replacing the whole alternator. Tried my usual online sites but no luck.
2007 trojan.
My alternator completely gone.not cheap to replace them so reconed it for 80 quit.bushes or bearing on the way out i d say so get it checked and keep an eye on battery voltage if its below 12-13 then its not charging the battery so can damage that too.cheers
Try milners 4x4 or failing that ask on the L200 forum.com good bunch of lads lasses. Are you sure its not the crank pulley one sqeeking. Only asking as there their laminated and fail causing major damage.
mike
mike
Milner is my usual go-to but no luck in this instance. I'm 99% sure it's the alternator pulley - I know it's fairly rudimentary but i spray a little wd40 onto the various pulleys a day apart and the noise immediately stopped when the alternator pulley was 'lubed'. Of course came back a few days later.
I'll r try my local garage and ask about an alternator recon. Thanks guys.
