Tungsten Chains
Jamie
Hi all,
Quick question, we have a job removing part of a stump next to wall that is being re built. how well do the tungsten chains stand up to cutting through soil and all the crap buried within a stump. I've never used one. i've searched the old forums etc but looking for some reassurance. if they will be ok, the company has no problem buying a few as throw away items so longevity isnt too much of an issue.
jamie
It has been a long time. branching out into new ventures. Missing the trees though.
I have previously cut most of the stump i can down, it's now down below ground level. Are the piranha a standard chain. i just don't fancy changing chains every 10 minutes. (or more importantly, getting the random chainsaw user to change chains every 5 mins).
I've looked at stumpgrinding but it's pretty inaccessible and atop a crumbling wall 15m above a railway line.
I've thought about slinging it witha rubber duck and teasing it out but the client are concerned about ripping the wall apart.
Jamie
The tungsten chains can also snap heads - and prob will trying to cut into the ground if there are stones. You are better (as said) buying the cheap and cheerful piranha chains, give them a harsh and fast sharpen a couple of times then replace.
