Alpine tractors
GLMlincs
Never seen one but I think a micro timber crane like the ones on the atv trailers mounted on a jake plate leaving the 3pl free for a winch would be a great setup. Or maybe a short king post version mounted where the rear roll bar normally goes... just need a bogey trailer then..
We sold one to a customer last year for exactly this purpose and he is very pleased with it. Its a 3.4m reach. I still have one in stock with this 3 point linkage setup.
I was thinking the exact same thing and saw that crane on eBay , on your one in the photo is it mounted with legs ? Also how is it powered ? Our AGT has a front pto so was thinking this could be hooked up and the winch still used , we have mounted a tow bracket on the winch for the chipper which although does not have suitable tyres and will carve trenches in soft ground where the tractor won't it's handy, was thinking a light weight timber trailer would work well and the crane and winch still be used.
Yes, the one we have has got the black subframe and hydrualic legs. It has standard 3 point linkage fittings on the tractor side. We can put either a jaw and pin or 50mm hitch on the back side of the subframe, then you can tow a timber trailer with it. You can just power the crane from the tractor hydraulics, they dont need much flow.
