Slab/beam for mantle
wisewood
I've been asked to source some timber for a mate.
I've got a few logs that I could mill but I suspect it would really need to be kiln dried.
They're looking for either salvage beam/sleeper or alternatively an interesting looking slab/beam.
Location north west, Southport,Liverpool area.
Anyone near here got anything?
Cheers, Si
This is my mantle piece which was the rough end of a 12 ft beam I bought from a mate. It was just milled With an Alaskan and left out side for a couple years. I just finished it with a hand plane and stuck it to the wall. It hasn't moved a lot only on the end with some decay and a knot
[ATTACH]201675[/ATTACH][ATTACH]201676[/ATTACH][ATTACH]201677[/ATTACH]
Thanks Will, what dimensions did you go with?
Also, what fixing method did you go with?
Si
Si
5 1/2 x 6 1/2 inches and I used threaded steel bar hammered into holes in the beam and then 2 holes into the wall fill them with grip fill or the like and hammered the whole thing home with a sledge.
[ame]
[/ame]
Not sure that link will work but just type in 'how to fix a mantelpiece ' into Google and there is a short video of a northern builder who shows you how to do it.
Hope that helps will
Thanks mate 👍
i have some spalted beech beams with a few splits at 5 1/2" square. 2 years air dry.
i also have some sycamore at 5"-5 1/2" thick and could be cut at a wider width. drying for 5-8 years and is bone dry...
Thanks, the sycamore might work.
I need to check with my mate but if the chimney breast is 56" then 4 ft would probably do it.
Could you pm cost if cut to 8" please? Cheers, Si
