This is for felling forward leaning trees, so the tree is going to want to go early. If you leave a strap at the back you hold the tree while setting the hinge, when you sever the strap you can do it in a number of ways: level above the cut or in the cut - the tree is likely to break the holding wood before you fully cut it and can take the saw with it or cause it to kick; level underneath the cut - the tree is again likely to break the holding wood before you've severed it fully, possibly causing the tree to split at the back. The cutting down at 45 degrees keeps the strength in the wood fibre, meaning the strap is less likely to snap or at least will hold on longer, the angle of the cut means that the saw is less likely to be taken with the tree.
That is the way that I understand it, but if anyone's got more knowledge I'll happily learn.
Thanks for that. :thumbup1:
  • Replies 70
