That's a breather on a gear box and it shouldn't have hydraulic oil in it
How to stop it is probably the wrong question, why has it started spitting oil out is probably a better one
What's a z20E?
Edited by treequip
What's a z20E?
cherry picker mounted on to a datsun cabstar i believe.
There is nothing scary in there, undo the row of allen bolts that are on the same plane as the vent cup and pull it out. If you clean up the tag thats riveted to the motor by the vent cap you should be able to get a seal kit for it by quoting the numbers on it from any decent hydraulic shop.
Bob
  • 5 years later...
Just got one to do a job on house and had no oil in the site glass top or bottom Iv out 3 gallon in but still not seeing any in glass .. it works ok but from cab with on one in,,, but when I use the cage it gets half way up and want work …
