Double ended milling
wisewood
I'm currently milling with an 066 with either 36" standard 3/8 or 42" lo pro.
I've been hankering for an 880 but I'm wondering about getting another 660 to run both powerheads as an alternative.
My main question as I usually work alone is, is it possible to mill with two powerheads with just one operator? Has anyone rigged up a trigger cable that would rev both saws simultaneously?
The power is nuts and the difference between the pushing and the pulling side is huge.
The start and the finish is the bit you would struggle with yourself even if you managed to set up a trigger gizmo.
Also the operators need to work together and you both don't run full tilt, 1 does and the other balances things out when you hit harder or softer wood.
Difficult to explain .
I've worked with 2, 088's on my double mill
Just picking up tips at the moment Stephen, I have a chainsaw mill, but haven't had any time to break it out in anger as yet...
The rope comment interests me - you mean that you operate the saw from the trigger, but instead of pushing the mill with a combination of saw handle and centre handle on the mill, you pull a rope attached somewhere?
I'm not sure I have the right mental picture here, do you have an image or more info?
