So I have an 07 Iveco daily 35c12 doing a bit of work on it the other day moved it six ft then it wouldn't start. It had warning lights ( car and padlock ) any way a couple of fuses had blown a 5 and 10 amp replaced these and the warning lights went off but the EDC light stayed on and it won't start , it turns over , sprayed with easy start and it goes but not without , primed fuel up to the filter. Any ideas please.
You say you carrying out work on it? Any chance you been welding or short circuit the system?
You may have to have it re-set has may have gone into limp Mode, try disconnecting the battery and leave alone for ten mins .
Ste
Edited by IVECOKID
We where on a job last year, there was a Iveco van with cherry picker on, that came up with similar symptoms you've said, cranking over but not firing and a warning light on. The lads with the van had this problem before, and just took the keys out and walked away far enough for the chip in the key not to be read by the van left it for a couple of minutes, came back and it started OK.
I know it wont help you fix it, but might get it running again?
