  • Replies 30
Rope onto towball with a pile hitch for pulling with a vehicle
try using your capstan tie onto rowball with a little loop and can always undo rope no matter how much riving you do
Anyone else oldschool enough to use a waggon/carters hitch to tension a pull rope on a tree being felled.
Yep used it a few times. best to know thew old school tricks. also used a (steel) carabiner as well to reduce the friction :proud:
Jamie
Other than the usual climbing knots, the carters/truckers hitch is probably one of the knots I use most, and i'm not old school by any means, i've used it to tension lines, pull over stems/trees, drag out timber and tie down loads.
You can double up carters hitches and add biners to reduce friction a top multi-use knot, you got to love multi-use.
Attaching the pulley, timber hitch on large trunks and cow hitch on smaller trunks
Lowering down big section, running bowline with half hitch
Tying to truck or tractor, I use a port-a-wrap attached to my tractor and put the rope on it with 4 wraps and a couple of half hitches around the little stubs. You can pull as hard as you want and there is no knot to tighten and it doesn't bend the rope a lot.
not used it in a while but have done, used a load of micro cenders b4 as well
or forget the capstan and use a sling with a friction hitch.
