Just piecing together a (very) basic starter kit for the new year with a budget of around £400 - does this look a reasonable starting point?
I've just used the tree hog as a marker until I try some harnesses out to give me an idea on my budget for now.
Any recommendations, anything missed, swap-outs? :confused1:
0B9QX_BaFFwHcYW5ncUxJWGNCZ0E?e=view
  • Replies 21
Most of the big suppliers do a starter kit for around your budget, have a look around.
The one below is from Skyland, comes in at £425 with a treemotion light harness that is quite well thought of by many
http://www.skylandequipment.com/progressive-climbing-kit.html
The only other things you would need that don't tend to be included in these kits is a set of spikes if you plan on doing takedowns, and potentially a throw line if you will be accessing taller trees
Sorted?
19l5D7uAAB9H9UImgnPuy6HlyZkDBFfIe1KcGHnycnc?size_mode=3&size=1024x768
I'm thinking spikes and throwline in the future.
I'm only doing my cs38 in mid-jan, and as I have no arb job lined up as yet, I'll just be rec climbing and gaining experience for a while
Edited by diervek
As Steve said, 5m or so of 13mm rope for a lanyard, preferably a different colour to your main line
Don't forget a climbing helmet as well just in case, and make sure when you rec climb there is someone else about
Pretty much what everyone else has said but Google all the Arb suppliers and ring round. Give them a budget and see what they will do for you. Good luck and I hope you catch the bug :biggrin:
All looks ok, I assume the 9mm Boa is for the friction hitch on your climbing line.
Someone has mentioned a lanyard, in addition to the length of climbing line you'll need
2 x Karabiners, I use a DMM Ultra O on the side that stays clipped and a DMM Boa on the side that gets clipped off/on.
Another length of 9mm Boa for a friction hitch on the lanyard
1 x Micro Pulley to advance the friction hitch on the lanyard, I use an ICS Small Single Pulley.
For Aerial Rescue you'll need,
Spare Prussik loop c/w Karabiner
Webbing Sling c/w Karabiner
Possibly a Figure 8 descender c/w Karabiner
Also a 1st Aid Kit, a Knife (the course book mentions a folding blade), Whistle.
Climbing Helmet, I use a Petzl, can't remeber the exact model.
If you're spiking then you'll obviously need spikes and possibly a wire cored flipline, I use a Honey Brothers Wire Core with Swivel Snap-Lock. you'll also need a friction hitch, another micro pulley, again I use an ICS Small Single Pulley and another karabiner.
so in addition to what you already have
4 Karabiners (5 if you use a figure 8 descender, 6 if you need a flipline)
1 Micro Pulley (2 if you need a flipline)
2 Friction Hitches (3 if you need a flipline)
1 Webbing Sling
1 Figure 8 Descender (possibly optional, if you don't use it you need one less karabiner)
Knife
1st aid Kit
Whistle
Climbing Helmet
Wire Core Flipline + 1 karabiner if the flipline already has one fitted
Climbing Spikes
I think that should cover the basics needed for CS-38
Phone http://www.treeworker.co.uk/ and explaic what your doing.
