I got a HC55 that seems to have electrical gremlins on that complicated forward/reverse control. It has been slightly wayward but we managed last year. Yesterday, I managed to get it moving, via wire wiggling, but it stopped. I cannot seem to get forward or reverse now.
Anyone got a Wiring diagram or hints on what to look out for? Anyone converted one to mechanical controls?
Right now, I want to get it back into the shed before it blows away!
Micro switches have a mechanical service life, something like 100000 actuation before they degrade. And an electrical life of say, 5ma for 5000 hours or something. Easy to test.
Sent from my D6603 using Tapatalk
They are very good. 5 or 6 amp contacts in something that size is pretty amazing. Most of mine are subjected to high temperature, humidity up to 98%, vibration and the occasional hot bath. To be fair to the little beasts a big proportion of failures would be in the activation mechanism, dirt, dust etc, something for the OP to check.
You mean at the handlebar end? Tried the usual - clean, wipe,blow,WD 40 etc....wondered if anyone has affected a manual conversion?
Yes but remember I've no idea what the machine is. If you have micro switches pull a wire off and test with a meter. Contacts are hidden on the inside but the switches are as cheap as chips.
