husqvarna t540xp oil leak need help
Timberman675
  • Replies 31
Yes screw driver in one of the cut a ways in the clutch swift smack with a hammer, make sure the plug is in so as you have good compression to jar against, the screw you have missing goes into the front av mount, so needs replacing, you cannot remove the base plate without spending a lot of time, removing car and tank etc, once the clutch is off you need to remove the plate behine to expose the oil pump, if the saw has had a new bar make sure it is the correct one and the oil holes line up.
