What is the largest bar a 9010 will run ? Also I am struggling to locate sprocket nose bars for this saw,any one point me in the right direction,std solid 28" bar just about worn out now.
Thanks
Jez
  • Replies 23
Thanks
Jez
Contact shavey on here, he can supply the parts needed (only a few quid) to convert to D009 mount, which will give you loads of bars to choose from. see post
http://arbtalk.co.uk/forum/chainsaws/84360-dolmar-10.html#post1311991
Pete
Thanks
Jez
38inch easily... probably bigger.
Shavey will sort you a bar.
Thanks
Jez
Hello Jez there are a couple of options for you
No1 keep the existing EU D033 bar studs and I will prepare you a large mount Stihl bar and adjust oiler hole and you can have which ever length you want
No2 send me down the bar studs and I will adjust them then you can use any D009 bars ie large husky mount I will send them back with any size bar you need
Option two will be cheaper and better in the long run :thumbup::thumbup:
Thanks
