Hi all,
I'm thinking of getting a timber trailer to use behind a quad, has anyone for any recommendations or ones to avoid?
I've found the one at the link below any thoughts? Would be better if it had inserts so cut and split logs could be carried though...
https://www.kellfri.co.uk/tipping-and-forestry-trailer-for-atv
Cheers
Mark
Hi mark I think the village idiot uses one so he will know about that and there's loads more of your chaps on here to all the best Mark happy Christmas John
i,ve got one of those. have never tried the crane though. pretty well made but easy to unseat tyres if you take a sharp lock with full load on.
Hi s o c, what's the build quality like? It's hard to tell from the web site? I've also just found one from Iorn Baltic which looks good but the box bed is separate.
Cheers
pretty good. as strong as you could build it without making it heavy. tipping body is very well made. weve always loaded it by hand and had mini digger or roofmount at road to unload. might fit tubes to sort tyre issues
Hi all,
I've found the one at the link below any thoughts? The inserts so it can carry logs etc looks handy but perhaps lacks a bit of robustness...
Cheers
Mark
This looks similar?
[ame]
[/ame]
