FS460 stripped thread on handlebar bolt assembly
porky
That's the handlebar bolt, that's ok, its where it enters into the plastic body below.
I've just googled 97990030410 and that is a helicoil which would sort it thanks.
Be very careful when drilling for the helicoil there is very little meat on the insert. I do it because the blokes like the quick release but the bolt and nut makes more sense. I use 2 6mm helicoils.
