  • Replies 149
Finally took it for a spin today, saves loads of time & back ache! i have found out that the clutch is paggerd on the tractor pto though!
Nice little job over the hols replacing clutch on DB , fun and games they can be .
Ste
I have been told there is some adjuster springs may need altering, failing that the tractor needs breaking!
Yes if you have a dual clutch you can adjust by removing the inspection cover of the bottom of the bell housing and using a torch you will see on clutch cover a locknut with a Allen key inside,memory serves me correct there is 3 or 4 of them BUT BE WARNED you get it wrong and you will lose the clutch feel completely and you will piss about for hours getting it back.
You can adjust on foot pedal to take up slack on stage .I have a factory workshop manual for 885/995/996
Ste
