  • Replies 40
  TimberCutterDartmoor said:
That's a 670/680 in the top pic. Theoretically, a Shindaiwa 598 aka CS600 should never have a "Kioritz Corp" serial number, only a Shin or Yamabiko Corp one... The one in your pic does which suggests it's a red Echo and they aren't orange Shinny's!
There's an assumption that the Shinny 598 is it but apparently not so. I think in truth it's borderline around the time they merged officially since they were parlez-vous'ing on engines and chassis 18 months prior to the merger date...
ANd then there's the photo up above...
  • 1 month later...
I'm tempted, does anyone know if there's options to change from .325 to 3/8 lopro?
Have they got rim sprockets?
Anyone know what the bar mount is? I'd want to fit an S1 carving bar.
Just read the service manual👍
It has a rim sprocket so shouldn't be too difficult to swap to lopro. Couldn't see any info on the bar mount though.
It uses the same 041 mount (OREGON) as CS-500 (the only difference is tensioner located in clutch cover).
The rim is "small 7" which means it's 18720 for a 3/8 (OREGON)
Sure, you can look up analogues from other manufacturers based on this info.
Read more
