I need to price a good quality ride on mower. The spec is
No timed blades as tooth belts can jump when obstacles are hit.
About 4 acres to be mowed. Lawns and paddock, a little area might be cut up and down as a bit steep to cut across.
Diesel, hydrostatic, mulcher with an occasional pickup facility.
Fairly maneuverable but no really tight areas.
Price not so important as quality and performance.
One thought is the Countax A series, any experience of these.
Thanks
  • Replies 32
Thanks for confidence guys, but to be honest, diesel machines are not my strong point and I have a strong dislike of Countax/Westwood machines, so may be a bit negative.
I specialise in Stiga and JD petrol machines so if these are of any interest give me a call. You can find my website by googling gardenkit.
If you are going to do some paddock mowing then stay clear of Domestic style mower , you will burn belts out quicker than you can think .Countax/Westwood are excellent mowers for Domestic use but awful for heavier grass and plagued to death with puncture's!
Has mention above Stiga out front mowers are well built and very manoeuvrable , has for Kubota's they are well up to the job but much heavier and expensive same too with John Deere's built for the job .
Has for mulching , great when its bone dry and cut regular but makes a balls of a job when its wet and tall .
Ste
Edited by IVECOKID
I'll have a look thanks Barrie. Really ought to be diesel though as we have it on site and fetching petrol in cans is another job on a long list.
BTW. I did sense your slight dislike of Westwoods transmissions yesterday.
I sort of agree as a couple of the most used mowing gears are showing signs of wear on my machine and I did have to replace a half shaft on the one at work but that had reason to shear unlike the lightly used one in my picture. Normally I do use a smaller two wheeled timber style trailer but I had a lot to shift that day.
