not much mate....cant see exactly how the splice goes. it appears to just go in and through the core for 30cm then out again forming a loops, then back in again. can someone confirm that? and also the loop....im assuming its for adjustment?
i think the loop is to allow the stem to grow in girth without being strangled. i.e as it thickens the loop is taken up. also means that in the future it can be visually checked from the ground. if the loop has gone then theres no more leway for the stem to thicken and the system needs to be re-installed/adjusted.
